Z2 Doesn't know where I am anymore...?
By StaticFilter · Jun 21, 2010in Problems/Troubleshooting💬 8 posts👁️ 1,379 views
Posted Jun 21, 2010 · 22:18 UTC#1
So my GPS is screwed or something. My NAV doesn't know where I'm at and if i set my position manually, it gets lost within a few days and shows me driving through city blocks and in the mountains etc... Isn't there a way to make it find it's position via satellite?
Posted Jun 22, 2010 · 14:31 UTC#2
Check via the hardware menu if you're actually receiving sufficient satellites. If not, perhaps there's a bad connection, or a defective GPS antenna.
You can also try resetting the calibration, that often helps in cases like this....
Posted Jun 22, 2010 · 21:43 UTC#3
any detailed steps i might take to do this?
Posted Jul 06, 2010 · 02:38 UTC#4
Gather anything from these pics? When i try to reset calibration, it stays on "Sensor Initializing"... what do i need to do?
Posted Jul 06, 2010 · 08:04 UTC#5
According to the last screen, you seem to be receiving zero satellites. Unless your car was parked inside a garage, either the connection to the GPS antenna could be loose, or your GPS antenna is screwed.....(assuming it was working before)
Posted Aug 28, 2010 · 00:17 UTC#6
I am having the same problem with my Z1. But instead of what you are experiencing, I am getting a message on my hardware screen that says, "NOK" after the satellite section, with a message that states that there is a problem with my antenna. I am going to buy a new antenna and see of that helps, I would recommend you do the same, an aftermarket, non-Pioneer model is going for about $10 on eBay.
Posted Aug 28, 2010 · 01:03 UTC#7
Have you double checked that your antenna isn't just disconnected? NOK can also mean that the wire is unplugged.
Posted Sep 08, 2010 · 03:00 UTC#8
Well, it's really weird, because it started working again mysteriously. It found exactly where I was and now shows 10/12 satellite connections. I was actually just about to pull the unit out and check the connection, but I'm gonna leave it alone until it does it again, or I have to pull it out for another reason.
Thx for the suggestion tho and I will check that next time.
