Bluetooth newbie
By funtimeguy · Jun 25, 2010in General💬 4 posts👁️ 1,120 views
Posted Jun 25, 2010 · 05:17 UTC#1
I just had the X920BT, with all the goodies, installed in my Honda Ridgeline. I love the stereo, works great, but I have one problem. Most people are probably old hands at using bluetooth, but I've never really used it. I didn't have much of a problem getting my phone (Motorola Droid) to sync up with the radio and transfer my contact list, but I can't seem to get music or video from the phone to stream over bluetooth to the X920BT. I must be missing something, any help would be much appreciated.
Posted Jun 25, 2010 · 06:20 UTC#2
There is no BT video support with the unit and as long as your phone supports BT audio streaming it should be working properly.
Posted Jun 25, 2010 · 07:14 UTC#3
That's the problem, the phone part works, the wife called and the radio picked it up and we both sounded good, but if I play music on the phone I can hear it on the phone, but not through the radio using BT audio.
Posted Jun 25, 2010 · 08:46 UTC#4
Here are some suggestions....
1) You may want to check your Bluetooth Connection Priority and make sure that your phone is setup to be used as the BT Audio Device..See Manual (Link Below)
http://www.pioneerelectronics.com/Stati ... al0129.pdf
2) Are you choosing BT Audio on the A/V selector on the left? The A/V menu option should be there when your phone connects to the head unit...See Manual (Link Below)
If you continue to see that this feature does not work, it may have something to do with the profiling for your phone. It has to be able to transmit audio over Bluetooth to begin with and use either or both A2DP & AVRCP...The acronyms are explained in the manual also...
Peace ~ HFoM
