F900BT Problem
By MK4NOR · Jun 26, 2010in Problems/Troubleshooting💬 8 posts👁️ 1,340 views
Posted Jun 26, 2010 · 01:14 UTC#1
Hi to you all :=) im new.
But i got a serious problem with my F900BT.
i'ts preowned and its suppose to work as normal.
It's also in Italian.. and im Norwegian.. cant go to settings to change it, nor can i use the SD card to update.
Some pictures:
http://img413.imageshack.us/slideshow/w ... ny0201.jpg
Yes, i have bypassed it. and i have checked it several times.
the weird thing is that music and the GPS works perfectly.. but i cant use SD card, usb, phone etc.
but i seriously need help.
Thank you.
Posted Jun 26, 2010 · 01:42 UTC#2
Looks like your bypass is not done correctly. Those options are grayed out because it believes the parking brake is not set. Set the parking brake/correctly do the bypass as described here.
Posted Jun 26, 2010 · 14:26 UTC#3
Fixed it! can access the setting and the phone bluetooth etc.
also, i can watch dvd while driving!
But i still have problem with accessing my SD-Card.
Is this because it doesnt read my HC Card?
i really want to update my FW :( its 1.06000 :<
Thank you.
Posted Jun 26, 2010 · 18:25 UTC#4
Only way to know if it is your card, is to try another SD card...
Posted Jun 26, 2010 · 18:48 UTC#5
Looks like it doesnt matter if i use normal SD or SDHC... still doesn't work..
tried SDs with music and with the FW update.. he just wont read it.
Any suggestions?
Posted Jun 26, 2010 · 21:10 UTC#6
Make sure it's formatted as FAT32?
Posted Jun 27, 2010 · 04:21 UTC#7
No luck..
Formatted it as FAT32, and nothing..
Thanks again.
Posted Jul 04, 2010 · 20:08 UTC#8
Everything works.. i can watch DVD while driving, i can type adresses in the for the GPS.. i can use USB, CD,DVD everything! just not SD card reader.. why not? is there another way to update the FW? or is it something wrong with my Bypass that makes the SD-card greyed out?
Please help me!
Thanks in advance.
