2007 HONDA ODYSSEY
By A&ICUSTOMS · Dec 17, 2006in Hacks/Mods💬 8 posts👁️ 5,093 views
Posted Dec 17, 2006 · 21:55 UTC#1
DOES ANY BODY IN HERE KNOW THE WIRE DIAGRAGRAM ON A 2007 HONDA ODYSSEY VEHICLE HAS OEM XM RADIO AND DROPDOWN TV NEED WIRE DIAGRAMS ALSO FOR OEM DVD AND VSS :?::?:
Posted Dec 18, 2006 · 00:59 UTC#2
um, isnt the dvd integrated into the factory radio, and if you remove the radio you disable the dvd? but 07 and 06 are the same, it was the civic and crv that changed in 07
Posted Dec 18, 2006 · 01:12 UTC#3
YES IT DOES BUT THE DVD IS IN THE LOWER PART OF DASH BOARD.
WHEN I REMOVE THE RADIO OR TWO GREEN PLUGS THE DVD AND DROP DOWN TV STOPS WORKING SO WHAT I NEED IS HOW TO INSTALL DROP DOWN TV AND XM RADIO INTO THE Z1 IS THERE ANY CONVERTER PLUGS THAT I COULD GET TO MAKE IT WORK
Posted Dec 18, 2006 · 04:59 UTC#4
Ok first of all please turn off the caps lock. Second what specifically are you looking for in the diagram. I'm guessing a way to keep the overhead working without the stock raido? As stated before 06 and 07 are identical.
Speed Sense blue/white PCM, conn. A, pin 29
Notes: The PCM (Powertrain Control Module) is on the passenger side fender.
merry xmas
Posted Dec 19, 2006 · 01:47 UTC#5
that is correct trying to keep factory drop down working with new z1
Posted Dec 19, 2006 · 04:10 UTC#6
hmmm, I dont do those, we just steer clear of them.
Posted Dec 19, 2006 · 04:23 UTC#7
DAMN .........
Posted Feb 06, 2007 · 15:09 UTC#8
hate to be the bearer of bad news. but you are in for a tough one here.
Most likely you will NOT be able to control your factory dvd/ screen Via ANY aftermarket Head Unit.
You may howver uninstall your factory screen, and find the Video input lead on the Circuit Board. (i dont know where/ which leads they are, I havent done one yet) and convert the Video input solder point, to a standard RCA, and plug that RCA into the Z1.
you would basically be converting your factory, into a monitor only, fed from the Z1 (you put the dvd in the Z1 and use the Z1 to control what is playing)
you may POSSIBLY also find the needed wires on the back of the factory dvd player.
HONDA would be your best place to start as far as a diagram goes, or at least to find out WHO exactly made the factory DVD/radio setup. (Panasonic... Clarion... etc..)
Definately NOT for the basic installer. Ive been Installing for 11 years, and if would take me a while to figure it out.
Wolfz23
