i have an antenna that is integrated into my glass, my harness has a wire that says power antenna, what do iconnect that to on the d2 i have an 06 92x
Posted Dec 18, 2006 · 02:38 UTC#1
The blue wire from the avic goes to that auto ant. lead.
just thought that is what sends signal to raise-lower ant. or an amp, once again thank you, btw if i do hook up an amp later is it also to that wire.
No, you will use the blue/white wire to turn on an amp. The solid blue only energizes when the AM/FM tuner is being used.
though there is a menu option to make the blue wire work the same way as the blue/white wire. ![]()
So true, so true. Forgot about that.
