I plan to remove the Yellow/Black cellular mute wire and use it for the bypass ground wire. For all of you that have done the bypass, what is the best (read: easiest) method of removing the wire from the harness? I'm trying to make this as smooth as possible. Thanks in advance.
Posted Dec 18, 2006 · 13:38 UTC#1
