General Speed limit sign issue with ALL mods
By skyblaster · Jul 04, 2010in Hacks/Mods💬 6 posts👁️ 1,210 views
Posted Jul 04, 2010 · 16:13 UTC#1
Been looking at this board since i got my F900BT over a year ago, never had to register until now because of this problem... I'm in Canada and will explain the problem and pray for a solution
Any nav UI mod that i've loaded which has a speed limit sign displayed is always incorrect. By that i mean:
Say i'm traveling on the highway with a speed limit of 100 km/h, The UI will show a speed limit of 161km/h.
Best i can tell is that the map data indicates a speed limit of 100. Something thinks that that 100 is in mp/h and converts it to km/h (100 mph = 161kmh).
This happens anytime the map data contains a speed limit, but current speed always shows correctly. Can someone help me out with this? if it's relevant i'm currently using daftias mod.
Posted Jul 04, 2010 · 20:35 UTC#2
Well, if you had this issue with ALL mods, then it is my assumption that you did not delete the user data files when switching mods. I live in Canada as well and my speed limit signs are always right on no matter what mod I use. You MUST delete the igo folder in the userfiles though when switching mods
Posted Jul 04, 2010 · 20:40 UTC#3
if i go delete that folder right now will it affect anything even though the mod is already loaded?
Before Daftias mod i never saw instructions to delete any save files (which i did when i loaded this one yesterday)... Before this mod it was IDT's and had the same issue, i don't remember the mod before that but it was the same deal.
Not blaming the mods, i know it has to be something local but i've been stumped. I'll go delete that folder and see what happens.
Posted Jul 05, 2010 · 00:22 UTC#4
Make sure that you delete the right folder. It is in 'My Flash Disk\USER\UserData'. Then just delete the entire 'IGO' folder. You have to do this whenever changing mods
Posted Jul 05, 2010 · 00:28 UTC#5
Just drove home from work after deleting that folder and speed limits where correct!
Many thanks
Posted Jul 05, 2010 · 00:33 UTC#6
Many thanks
Excellent, glad it worked out for you! just remember that whenever you change mods or even major updates, ALWAYS delete the igo folder in the userdata
