GEX P920XM defaults to channel 0
By soobyscooby · Jul 04, 2010in XM/Sirius/HD Radio and Traffic Receivers💬 3 posts👁️ 1,805 views
Posted Jul 04, 2010 · 19:16 UTC#1
I have the GEX P920XM tuner and F700, whenever I start my car it defaults to channel 0. Does anyone know how to make it default to the last channel I was on when I turned off the car? Thanks!
Posted Jul 20, 2010 · 12:52 UTC#2
You have it powered (wired) up wrong. If you use the IP BUS, you only need one of the two leads connected to power...and it must be to a constant 12V...not a switched. You more than likely have it to a switched power supply so it loses it's 'memory' every time you turn the key off. Read your instructions carefully. Either the red or yellow doesn't get attached when using the BUS.
Posted Aug 14, 2010 · 23:45 UTC#3
03Aviator thanks for the reply, I'll look at the wiring
