Just to start off with, ive bypassed quite a few 110's with absolutely no problems, this one is not going so well though
luckily this one is for an employee, so i dont have a pissed off customer sitting here every time i want to try something.
vehicle is an 05 H2. did the bypass same as i always do, worked great for 2 weeks and then started giving the improper connection message sometimes, other times just a black screen once you pass 15mph. after reading through numerous posts about people having the same issues, i tried reseating the pin, new grounds, a completely new pin that i pulled from the audio in rca, resetting the unit, and anything else i could think of. i know people are saying that the mute pin isnt making good contact, so i pulled the pin completely out, unplugged the rca harness, and just plugged the pin onto the correct corresponding pin on the back of the unit, still nothing. once you hit 15, it either throws up the message, or goes totally black until you slow back down again. i am completely at a loss on this one. i thought maybe i had screwed up the rca harness and was going to order a new one, but considering the pin plugged into the pin on the deck doesnt work, i cant imagine the harness is bad. anyone have any help on this situation??? thanks in advance.
