The interface choice is up to you doesn't really matter which one they both do the same thing.
2003 H2
Reverse Light lt. green + BCM, black plug, pin F
Notes: The BCM (Body Control Module) is located behind the headlight switch. It has 6 plugs in it, the purple plug is on the back.
Speed Sense dk. green/white PCM, green plug, pin 50
Notes: The PCM (Powertrain Control Module) is under the hood on the driver side next to the battery. The vss wire is also found behind the instrument cluster, and in the radio harness on some models.
Odds are for the vss, you can get it behind the radio. It's in the smaller of the 2 plugs that plugs into the back of your stock radio.
merry xmas
