Replacing D3 with X920BT
By Thermo144 · Jul 14, 2010in General💬 3 posts👁️ 792 views
Posted Jul 14, 2010 · 22:17 UTC#1
Hello,
I was wondering if anyone could help answer a couple of questions for me. I currently have a D3 installed in my Wrangler Unlimited with the proper dash kit and wiring harness to hook up to the upgraded speaker/sub system that came with the car. I was wondering if I would need anything new at all if I replaced the D3 with the new X920BT? Would the same wiring harness and dash kit work with the new unit?
Deleted! Forum rule violation.
Thanks in advance!
-Thermo
Posted Jul 18, 2010 · 16:36 UTC#2
make sure to follow the bypass instructions closely as there are slight differences between models, and as long as you already have a DD nav installed then you will have all the parts you need, you will just need to recycle them.
Posted Jul 19, 2010 · 16:12 UTC#3
Please update with how your upgrade went if you have a chance, i'm in the same situation and wondering if it will go smoothly or if I need to spend a few hours scouring the internet for walkthroughs
