Pioneer F920BT in Volkswagen Golf V GTI...
By guillaume.db · Jul 22, 2010in Problems/Troubleshooting💬 3 posts👁️ 1,887 views
Posted Jul 22, 2010 · 08:10 UTC#1
Hello
I have just bought a F920BT for my GTI.
Installation is completed but i have a probleme with the "Car Speed Signal input" and "Reverse Gear Signal input"
Could I connect them without can-bus adaptator ? (directly on the instrument panel ?)
If you have some information about that...
Regards
(excuse me for my bad english)
Posted Jul 22, 2010 · 15:00 UTC#2
Not sure on the VSS, but you can tap directly on to the reverse light for the reverse wire. If' things haven't changed between the MKIV and the MKV you should be able to tap the VSS wire directly.
Posted Jul 23, 2010 · 21:58 UTC#3
VSS is Vehicule Speed Signal ?
For reverse gear signal I will try to see if I can take it from DSG box
