Volvo XC60 with which AVIC
By jayce996 · Jul 22, 2010in General💬 6 posts👁️ 3,755 views
Posted Jul 22, 2010 · 20:52 UTC#1
Hi everyone,
I have a VOLVO XC60 and i've seen in youtube someone integrating an AVIC F500BT inside because it's a hybrid GPS.
my first question is: does the American version compatible with Europe? i mean if I buy an american model via ebay or thing like that, will it work in France? does it have the France map in it? or will I be able to "hack" it in order to install french voices and maps?
second question: do you know if a new model in the Pioneer portfolio is available and replace the F500BT? or does a similar model exist outside Pioneer products in the same range of price?
thank you for your help
BR
Posted Jul 25, 2010 · 15:08 UTC#2
hi, nobody can tell me if there is a new model similar to the F500BT?
nor inside or outside Pioneer portfolio?
pleaseeeeeee
Posted Jul 30, 2010 · 18:13 UTC#3
I don't think there is any stand alone Nav unit not in 2 din format can match F500BT. However, if I'm in Europe, I would seriously consider using Navigon 8410 in XC60. Check out my install using Cydle T43H, you can properly do the same with Navigon 8410.
Posted Jul 30, 2010 · 22:12 UTC#4
There is no replacement for the F500BT. You can also install other countries maps on the unit if you buy a US model. All info on how to do that is on this forum and will require a couple of days of reading.
Posted Jul 31, 2010 · 21:50 UTC#5
thank you guys for your info.
i will have a look at the F500 from US and the new navigon.
by the way PhilGood, who much is the integration of the GPS inside the XC60?
Posted Aug 01, 2010 · 22:43 UTC#6
DIY :) Check the installation instruction of Garmin nav unit from this link http://vccs.volvocars.se/accessories/ii/default.aspx.
I bought an extra piece of the facet (~US$ 40), cut a rectangular hole using dremel tool and follow the wiring instruction from above link. The wiring instruction should also give you idea how to wire F500BT.
