Map 3d to N mode?
By papilos · Jul 28, 2010in Problems/Troubleshooting💬 11 posts👁️ 1,833 views
Posted Jul 28, 2010 · 04:17 UTC#1
Is there a setting or reason why my 910 (when using the nav) map goes from 3D to N by itself? I hate this especially if i am in the (city) and can no longer see the streets but a map.
Posted Aug 04, 2010 · 12:57 UTC#2
I must say, I've noticed this problem with my AVIC-X910BT, as well. It seems to occur when a major junction is coming up.
Joe
Posted Aug 04, 2010 · 15:34 UTC#3
There are all kinds of SmartZoom settings (available from Navi settings page), although normally it switches to 3D when you are nearing an intersection and switches to 2D and zooms out when you are gong straight for a while.
Posted Aug 05, 2010 · 00:57 UTC#4
Ah, so this is normal behavior? Let me check the setting the next time I'm in the truck...
Posted Aug 05, 2010 · 16:17 UTC#5
The more or less normal behaviour (I don't recall if it is switched on in factory skin, though) is to show 2D map when there's more than 2 or 3 miles to the next maneuver, and switch to 3D, with progressively increasing zoom, as you are approaching the turn.
Posted Oct 31, 2010 · 03:14 UTC#6
Mine won't show the buildings in 3D is that normal
Posted Oct 31, 2010 · 06:48 UTC#7
3D buildings aren't supported for every city.
Posted Nov 02, 2010 · 04:00 UTC#8
That answers that.. Thank you.
Posted Dec 13, 2010 · 22:32 UTC#9
on a x920BT can you set it to do 3d just on or when turns are coming up. mine only seems to show and overhead zoomed in 2d. like the normal map just closer.
Posted Dec 14, 2010 · 00:45 UTC#10
No.
Posted Dec 17, 2010 · 06:10 UTC#11
No.
Thanks man. thought so but wondered if there was a trick.
