Bypass On/Off Switch?
By NightCrawler · Jul 30, 2010in Hacks/Mods💬 3 posts👁️ 2,184 views
Posted Jul 30, 2010 · 02:42 UTC#1
Hi everyone. I read the sticky on this bypass:
viewtopic.php?f=57&t=25867
Thanks dbnichols and other contributors for the write up. I am sure it will work beautifully.
I was hoping I could go one step further and set my avic unit video bypass up with an on/off switch so if I choose, I can just flip the switch and it goes right back to normal with the correct functions blocked. Do we have any electrical gurus that could advise on setting up a relay to ground and then a relay to the parking brake signal controlled by an on/off switch (or some other kind of switch) that would allow for both functions to work?
TIA,
NC
Posted Jul 30, 2010 · 06:59 UTC#2
Not sure its worth the effort to have a switch, but it you want to do it, you don't need a relay. Just go to Radio Shack or something and buy a cheapo toggle switch and run the parking brake wire to it
Posted Aug 13, 2010 · 14:13 UTC#3
Like the previous guy posted, a relay might be a little over kill compared to just running the switch by itself but.....
87-----GND
87a---N/C
85----GND
86---To one side of your switch, the other side of the switch to 12V
30----parking brake input to Unit
Hope this helps
Jaz
