I have recently completed the installation of an AVIC-Z110BT in a 2003 Porsche Boxster. The installation includes the “Hack”. I have the moved mute wire one hole to the left tying it and the parking brake wire together and tied them both to the original radio ground wire. I have the VSS and backup wires hooked up to the Z110BT. The system operates, navigating and playing music.
The problem is that the car doesn’t track down the road accurately, the road being laterally displaced 200-250 yards to the side if the car is on a cardinal heading, i.e., north, east south, west; 0-50 yards if the car is 45 degrees to a cardinal heading, i.e., north-east, south east, south west, north west.
I called Pioneer and got a hold of a surly tech who told me I had a problem with the VSS signal and didn’t want to hear anything else I had to offer. Oh, and he suggested that I reset the 3D Calibration Status screen values to "0".
Here’s what the system is indicating:
“GPS Status Screen” (page 92)
1. Speed Pulse: value flicks between 0 and 1 (car static), first bar in signal strength flicks between no bar and one bar illuminated; value increases to an observed 16-18 (car moving up to about 50 mph), signal strength bars illuminated to nearly ¾ total travel to the right, seemingly proportional to the digital value.
2. GPS ANT: 9 orange and 2 yellow satellites; signal strength, 3 bars.
3. Parking Brake: ON (with or without parking brake set)
4. Power Voltage: 12.4 volts (if I remember correctly)
5. Illumination: Follows headlight switch. (and dims display when head lights are turned ON)
6. Back Signal: On “low” until reverse gear is selected; then shifts to “high” before back up screen is displayed. SHOULD THE SIGNAL BE “OFF” WITH THE TRANSMISSION IN NEUTRAL OR A FORWARD GEAR?
“3D Calibration Status” (page 93)
1. Speed: With car static value flicks between 0 and 1 mph; with car moving indicates speedometer speed to within 2-3 mph.
2. Acceleration or Deceleration: Not noted while driving
3. Distance: 0.0 (after driving 50-60 miles)
4. Speed Pulse: (after driving 50-60 miles) 485,000+. Counts up in concert with the Speed flicking between 0-1 mph.
5. Learning Status: Remains at Sensor Initializing regardless of car use.
6. Inclination: Not noted while driving.
7. Degree of Learning: (after driving 50-60 miles) Distance – about half way across the display; Right Turn / Left Turn – no movement; 3D Detection – about one fourth way across the display.
This is my second AVIC installation....a Z3 the first time posed no problems (in a different car).
Bill
