Help with the wiring. Any body knows how to hook up to RSX
By guziran · Aug 02, 2010in Problems/Troubleshooting💬 2 posts👁️ 719 views
Posted Aug 02, 2010 · 23:22 UTC#1
Greeting
I just installed the AVIC-F900BT into my 04 RSX type-S and everything seems normal but the BLUE/WHITE which is the "APM TURNED ON" switch.
I connected it to the Red ignition switch and the system gives buzzing sound when I start the engine and it stays on(I guess it has the same frequency as the engine rpm), though it's barely hearable when I run the car, it's still quite annoying at the stop light.
If I disconnect the amp turn on lead, of course, it's totally mute.
Is there and "Radio Turn On" Lead on the head unit?
Any solutions?
I had an 06 S with F700BT. I could feel there was a sound of the electrical background, but not a buzzing sound. Wondering how the previous owner did the wiring.
Posted Aug 03, 2010 · 11:23 UTC#2
The blue and white wire only goes to an amp to turn the amp on. All your wires should match up color for color. If you are using a wiring harness.
