Lights On D3 Off
By littleromey · Aug 04, 2010in Problems/Troubleshooting💬 2 posts👁️ 834 views
Posted Aug 04, 2010 · 14:27 UTC#1
Ok, so now i'm a little confused and any help would be very much so appreciated.
When i am driving my avic d3 works fine, it will let me play dvd's as well as control my navi while driving. (no mods needed) however at night, when I turn my headlights on, it turns all those off and gives me, you cannot view while driving or what ever that generic message says about being distracted and driving.
I had a guy look at it and he didn't understand it at all.
You flip the switch on, and it shuts it all off... turn the lights off and everything works fine again...
Do I have a wire switched or something?
2001 vw jetta, avic d3
Posted Aug 05, 2010 · 14:28 UTC#2
you either have a bypass problem, an illum wire problem, or a internal problem with your unit
make sure that your mute wire is moved into the right spot and grounded along with the parking brake wire.
then verify that you illum wire is connected to the proper source, or try disconnecting this wire completely
also make sure that your avic's parking brake wire is not connected to your vehicles illum wire
