Z120BT Question???
By Prlauren · Aug 10, 2010in General💬 5 posts👁️ 1,263 views
Posted Aug 10, 2010 · 14:14 UTC#1
I Purchased and have been using my Avic-Z120BT But I can't seem to find the setting for mileage. I use to have a Z2 and when you pluged in your route in the upper corner it would give you the mileage to your destination. The Z120BT only shows in the top right corner estimated time of arrival. Does it have a setting somewhere that I am missing for the mileage.......or it does not have this feature?
Posted Aug 10, 2010 · 20:21 UTC#2
Just touch the icon in the upper right corner, and it will cycle through to the information you are looking for.
Posted Aug 12, 2010 · 19:03 UTC#3
Damn! That's easy.....I was cycling through settings and everywhere else. Should have known better but was use to avic-z2
Posted Nov 24, 2010 · 19:07 UTC#4
Actually...follow up question...
The X920BT looks like it will only cycle through distance, time, and arrival for the NEXT WAYPOINT, and not any later waypoints or final destination...at least the old D3 (god, I hated that f'ing thing) used to switch between WAYPOINT and FINAL destination data.
It appears the only way to see the arrival info for the FINAL destination in a multi-point trip is to bring up the little on-screen mini-menu and tap on the route overview button....this seems to show the checkered-flag, final destination data across the bottom of the screen.
Am I missing something??
Posted Nov 25, 2010 · 03:08 UTC#5
Nope, thats just one of the several points about the D3 having better nav then these new units. As time goes on, and you find the other short comings of these units, you will likely come to the same conclusion. Despite your hatred for the D3.
