X920BT full off ?
By Hellhammer · Aug 10, 2010in Problems/Troubleshooting💬 8 posts👁️ 1,616 views
Posted Aug 10, 2010 · 21:40 UTC#1
Is there anyways to get the remote wire to shut off, or to get the head unit to fully shut off ? I have a bose system and have been having issues installing the h/u I got it to work finally, but i hear a constant faint noise like you would hear in between tracks ? So I figured if there was a way besides installing a switch on the remote wire then that would solve the problem. thanks for help and suggestions.
Posted Aug 11, 2010 · 14:48 UTC#2
no the units do not fully shut off
Posted Aug 11, 2010 · 15:21 UTC#3
If you're hearing a hiss your install isn't done correctly either, possibly a mismatch of output levels to amplifers.
Posted Aug 11, 2010 · 15:38 UTC#4
its good, i was just trying to see something, but i got it figured out, thanks.
Posted Aug 21, 2010 · 21:02 UTC#5
what was the solution?
Posted Aug 22, 2010 · 15:04 UTC#6
I unhooked everything a couple times till i got it to not do it, So I'm guessing my connections just weren't clean enough, the only problem i have is if the volume is down and i accelerate you can hear it in the speakers. But it's only when the volume is below 3 thats it's able to be heard.
Posted Aug 22, 2010 · 16:18 UTC#7
i had accelerator whine in my mazda 3 until i put in a ground loop isolator, then it dissapeared
Posted Aug 22, 2010 · 20:15 UTC#8
Yeah, I'll get a GLI and install it eventually, its not that annoying yet LOL the main thing that is annoying is a typical problem where theres a shimmer or wave on the black bars around video, almost like its struggling to be solid black. Haven't seen any solutions or reasons for it yet.
