Just completed bypass & everything works fine, but there's always this warning on bootup about the PB wire not being connected properly. This warning appears before putting the car in gear. Not sure how it determines this fault because I could actually have the PB set at this point. PB status under SetUp/Nav is "ON".
ByPass on Z120
I believe there is an update that resolves this issue...
http://www.pioneerelectronics.com/PUSA/ ... 10BT?tab=F
Hope that solves your issue....
Thanks dawgbone. I've seen that, but it says for Z110 only. I hope'd they had incorporated that in this new version but doesn't look like it.
It is likely you have an improper connection with your bypass. Check your connections.
Sensor status says it's "ON".
I didn't pay attention to the thread title...
VBlue is right...
Otherwise.... run that update for grins....
VBlue42 -
If the sensor status says "ON" how can it be bad? If it weren't connected I don't believe it would detect anything unless I'm missing something about what the the sensor is looking for.
VBlue42 -
If your P-brake is grounded it will read on.... It the other(mute) wire that you moved over that isn't getting grounded... Check it's connection.... You may have not pushed the pin in completely.....
