Talk Feature?
By dcannis · Aug 12, 2010in Problems/Troubleshooting💬 7 posts👁️ 796 views
Posted Aug 12, 2010 · 23:13 UTC#1
I just had the Pioneer z110bt installed today? Why cant I use the talk feature? When I push the button nothing happens. I have the bluetooth mic setup. Also where is the pandora icon? Thanks for any help. I am loving this unit otherwise.
Posted Aug 12, 2010 · 23:53 UTC#2
A screen with the available commands doesn't come up when you hit the VR button?
How is yours setup? Are you using the RCA pre-outs to give signal to amps? or are you directly wired to your speakers?
There is a function in the setup where you can tell it what speakers to come out...
You will need to upgrade your unit to a Z120BT, to get the Pandora icon.... Although Pandora will still work with the Z110BT... You just have to fire the App up on your IPhone... It'll shut off the IPod and switch over to Pandora...<---You can also stream Pandora via BT as well....
Posted Aug 13, 2010 · 02:00 UTC#3
Thanks for the info! I plan on upgrading. Is it worth the $200? I am directly wired to my speakers straight out of the unit. Will I be able to use the talk button? Do I have to configure it and if so what setting is it under?
Posted Aug 13, 2010 · 02:02 UTC#4
When I hit the button no screen appears. If I hold the button for a few seconds it mutes the unit.
Posted Aug 13, 2010 · 02:32 UTC#5
What screen are you in when you hit the button?
Posted Aug 13, 2010 · 02:46 UTC#6
Turns out I didn't have the option turned on. I didn't realize it was a setting option. I turned it on then powered the unit down and back up and it is now working perfectly. Thanks for the help!
Posted Aug 13, 2010 · 15:11 UTC#7
Me either.... learn something new every day.... :wink::?
