Does any universal backup camera work on the avh series?
By EclipseAVH · Aug 15, 2010in Pioneer AVH Series💬 10 posts👁️ 10,843 views
Posted Aug 15, 2010 · 06:26 UTC#1
I saw some for like 30 bucks, will it work?
Posted Aug 15, 2010 · 16:43 UTC#2
any camera with a standard RCA video connection will work fine, you just have to make sure to get the right video signal for where you live
NTSC = USA
PAL = Europe
Posted Sep 09, 2010 · 23:26 UTC#3
Thank you for communicating !
on the avh-p4200 there is a brown connector for the rear view camera. and I see a few that only comes in yellow and red wires. I am currently using the video input for my phone which has video out. So I can't use that. Any idea?
Posted Sep 10, 2010 · 00:07 UTC#4
Any camera advertised as a back up cam will work. And are you saying you'er using the back up cam input for your phone?
Posted Sep 10, 2010 · 14:29 UTC#5
the brown RCA connector is for the video camera input, however most cameras outputs will be a yellow connector (pioneer only uses brown to differentiate between that and normal video inputs ) if the camera has yellow AND red or white the the camera also has a mic for sound that pioneer doesn't support (the camera will still work, you just dont plug the mic connector into anything)
Posted Sep 14, 2010 · 01:00 UTC#6
I installed a generic backup cam and it works great off the reverse signal. the only problem is on my 4200 I don't have the rear view button to view the cam when not in reverse. I see it shown in the manual and in demo mode but can't get it to appear for my, any suggestions? I am using the R/C (brown) connection
Posted Sep 14, 2010 · 01:19 UTC#7
What wire is the cam receiving power from?
Posted Sep 14, 2010 · 12:30 UTC#8
A seperate auxillary power feed.
I didnt see anywhere that stated the power needed to come from the deck?
Posted Sep 14, 2010 · 14:19 UTC#9
As long as it is switched 12+ it's the right connection.
Posted Sep 14, 2010 · 14:35 UTC#10
Yes it is, and the camera does work properly when the vehicle is reverse... I just don't get the option to view the camera at any other time. I do not get the rear off/on button and when I select the camera icon I only get Video/Ipod/SD for options.
