HELP! my car won't come out of park!
By firemaf96 · Aug 16, 2010in General💬 2 posts👁️ 995 views
Posted Aug 16, 2010 · 12:20 UTC#1
Ok, got in my car last nite and it is stuck in park! When I push my brakes I do not see my brake lights come on either.
Someone was telling me that it has to do w/ the Z110 that I installed, could this be true?
thank you!
Posted Aug 16, 2010 · 14:19 UTC#2
could this be true?
if it was working before the install and then quit working after the install was done , then yes, it sounds like something got messed up during the install, first off if your brake light are not coming on i would start looking at fuses first, pull out and inspect every fuse (not just the ones that say brakes) then makes sure that the switch at the brake pedal is plugged in to the harness and that the switch has not fallen out of its bracket (they usually twist and then pop out)
