Poor FM quality and AVIC Feeds trouble shooting
By hieracity · Aug 16, 2010in Problems/Troubleshooting💬 6 posts👁️ 1,438 views
Posted Aug 16, 2010 · 17:42 UTC#1
Hi guys,
I just recently installed the Z110BT and am loving it. I was really excited about the AVIC Feeds application and was able to use it successfully once (found a location on the app -> got in the car and paired my iphone to the HU -> the location i found was in the contacts with the pink M -> Hoorayyy!! :mrgreen: ) So a couple days later, I had entered a few locations on the application and got inside my car and paired the phone but my contacts from ACIV Feeds application did not transfer over. The initial location did transfer over. But not the new ones :cry: So what's up?
Secondly, the radio on my car was excellent before. Really good reception. But now, the reception is nothing short of crappy :x For all you southern Californians, I have trouble even getting 102.7FM on the freeway. That bad. Please help :?:?
Besides that, everything is in working order :D
TIA
G
Posted Aug 16, 2010 · 18:19 UTC#2
well lets start with getting a little more info here, what kind of car is it in? (year, make, and model)
a lot of newer cars have inglass or shorty "shark fin" antenna's that need to be amplified to receive reception, if your lucky the signal amp might be built into the car (as apposed to being built into the factory radio) and you just have to power the ant amp wire, some cars will need to have a antenna adapter with the amp built in to it instead (for EX: most VW's)
Posted Aug 16, 2010 · 18:35 UTC#3
I have a 2005 C230 coupe. Thanks
Posted Aug 17, 2010 · 13:48 UTC#4
mercedies, it does have an inglass or shark fin right? that sounds like its one of those cars that either need to have the factory amp powered (antenna, not audio) by connecting the avics blue wire to the blue wire in the harness, if this was connected, then you should try the antenna adapter with the amp built in
such as this antenna adapter, if you dont already have a signal amp built into the car
http://scosche.com/products/sfID1/151/s ... uctID/1927
Posted Aug 09, 2011 · 21:09 UTC#5
<!-- m -->http://scosche.com/products/sfID1/151/s ... uctID/1927<!-- m -->
I'm sorry. I disappeared for a while and just recently got back on the forums. Thank you for your input.
Posted Aug 09, 2011 · 22:02 UTC#6
no problem, good luck
