F700BT illumination color keeps resetting after 2.0080 updat
By dmas · Aug 16, 2010in Problems/Troubleshooting💬 6 posts👁️ 881 views
Posted Aug 16, 2010 · 17:56 UTC#1
Hi everybody
my F700BT was working fine with the 2.0060 update, I did the latest 2.0080 update a week ago and I have noticed that the illumination color keeps reseting when I customized stays like that sometimes for hours but then the colors start changing like when it was first installed, sometimes also the back camera is turned off, I have checked the wires and everything looks fine Ihave not lost my am/fm memory settings, it only happens with the illumination color, back up camera off, and sometimes some settings like the brightness of the screen gets reseted.
Posted Aug 16, 2010 · 18:22 UTC#2
i would try to redo the update, maybe one of the files got corrupted or that is just another wonderful bug with that version
Posted Aug 16, 2010 · 18:35 UTC#3
hi, thanks for your quick reply, that sounds like a good idea, but how do I do that ? I have tried installing the SD card and restarting the car with the card in it, but nothing happens.
Posted Aug 17, 2010 · 15:10 UTC#4
if it wont do it by itself, you may have to go into the system with testmode files and replace the "my disc" with another file from an older system file (which you may have to get from somebody else if you have never made a system backup)
there are a few threads with much more detail of how to do this in the mods and hacks section of the forum
Posted Aug 17, 2010 · 15:31 UTC#5
thanks 1loudls, I'll look into that.
Posted Aug 17, 2010 · 16:24 UTC#6
no problem and good luck
