No GPS reception
By TheRival · Aug 16, 2010in Problems/Troubleshooting💬 2 posts👁️ 571 views
Posted Aug 16, 2010 · 18:44 UTC#1
I purchased a used F700BT, installed in with the hard wire hack (grounding the parking brake). I have also installed the 3.1 update.
With that, i am not getting any gps signal. The antenna is plugged in and i have placed it on my roof unobstructed. I can see the satellites (red dots under nav settings/GPS & Time settings but it will refuse to lock on to any of them. I am wondering if this is an internal hardware problem or a bad antenna.
I just purchased a new antenna and it is on its way but in the mean time, is there anything I should be looking into?
Posted Aug 17, 2010 · 16:23 UTC#2
it could be either, when you go to install the new antenna, make sure that the plug is not damaged in any way
