Non-touch replacement for AVIC-90DVD
By shaun · Aug 16, 2010in General💬 3 posts👁️ 1,676 views
Posted Aug 16, 2010 · 23:15 UTC#1
I have an AVIC-90DVD nav unit in my car that is connected to an AVH-P7490DVD system (which has an AVX-P300DVD head unit) via the IP-BUS interface. The AVIC-90DVD is also connected to a constant NAV display screen (which is also non-touch) via the CD-RGB26P unit and then RCA cables.
This setup had been working great since it was installed in 2002, but about a week ago my AVIC-90DVD randomly died... and I can't seem to figure out why. The unit is getting power, it just doesn't turn on anymore. I've looked on eBay for replacements, and found one - but it has been upgraded to the 2008 map discs, which mean it is now touch enabled... and, I need a replacement to be remote controllable.
Obviously a direct replacement would be my cheapest and easiest option, but since that is the only AVIC-90DVD I have seen, does anyone else have any suggestions for alternatives that will work without touch screens?
Posted Aug 17, 2010 · 17:53 UTC#2
As long as you have the remote and the non-touchscreen disc you can downgrade a unit with the newer version. The thread with instructions to do this can be found here -
viewtopic.php?p=13060
Posted Aug 18, 2010 · 00:56 UTC#3
Thanks! I bought a used AVIC-90DVD with a broken bezel on ebay for $65! My install has it under the rear seat, so broken bezel is fine by me.
