Hey guys, this is my first post on here. Been using the site for reference but couldn't find anything that would help me with my problem.
I recently got a Avic f700bt and a boyo camera. everything works okay but the rear view cam doesn't work when I put it in reverse.
I connected the yellow camera RCA yellow to the brown RCA on the deck
I connected a wire from the reverse light to the reverse light signal wire on the deck (Purple and white if I remember).
I connected the camera red wire to a 12V acc wire
I connected the camera black wire to my main ground at the deck area
When I manually turn on the camera from the AV source I get an image from the rear view camera
When I place the car in reverse, Nothing... The camera doesn't switch on automatically...
I did some test on the reverse signal and when I put the car in reverse, the voltage goes up around 13V, when I put it back to park, the voltage goes back to 0V
If I switch the polarity in the settings/rear camera to neutral, the next time I turn my car on, the rear view camera stays on constantly, regardless if I'm in P,N,R,D ...I have to press and hold the map button for about 5 seconds to get out of that screen view and then I can turn it back to Positive polarity.
I should also add that I did the fx3.1 firmware image upgrade from this website at this link: http://avic411.com/index.php?/topic/27807-fx31-complete-firmware-image/
I'm clueless what could be wrong? is it software or hardware related...?
