(F700bt)Contact's name won't display on incoming calls
By yannthekeys · Aug 18, 2010in Problems/Troubleshooting💬 6 posts👁️ 1,764 views
Posted Aug 18, 2010 · 22:29 UTC#1
Hi everyone, i'm a french "avicist", i've just done the update on my F700BT from 1.9 to 2.009. I use an iphone 3gs, it transfers all the contacts, but when there's an incoming call, even it's from a registered contact, it only displays the phone number.
I've searched on this forum but " i still haven't found what i'm looking for..."
Posted Sep 13, 2010 · 16:04 UTC#2
I would like to know if this is fixable aswell. Even my old Parrot would display the Caller ID. My F9110 just displays the number, so i have to pick up the phone to see who's actually calling :(
Posted Sep 13, 2010 · 18:05 UTC#3
still no solution or answer...
Posted Oct 02, 2010 · 19:44 UTC#4
For me sometime the name appears sometime not ???
Chez moi c'est intermittent (ça doit venir que j'ai un dossier d'intermittent chez pole emploi !!!)
Posted Oct 15, 2010 · 13:03 UTC#5
Hi,
I had a problem with this and I solved it by making sure that my address book number is exactly the same as what is coming in. Some systems are smart enough to ignore the "+" sign and just match on country code area code and phone number, this isn't.
Being in NA I had to make sure that all my numbers in my BlackBerry contacts were in this format:
+15145551212
Because when a number was calling me it was coming in as:
+15145551212
not as
15145551212
Once I did that it worked, resent my contacts to the AVIC it worked. You might want to give that a try.
Posted Oct 15, 2010 · 13:08 UTC#6
Cheers, thanks for the tip. Will try later this weekend.
