F9110bt: unit switches back to defalut settings
By Omega01 · Aug 20, 2010in Problems/Troubleshooting💬 3 posts👁️ 720 views
Posted Aug 20, 2010 · 17:04 UTC#1
Hi all,
I own a F9110Bt and have one minor but bugging problem with this unit.
Every now and then (maybe every 5th startup or so), the unit switches back to its default settings.
The wired thing is, its not resetting all its settings but only language, voice, color, rear camera and monitor brightness. The EQ settings for instance remain as customized.
At first I thought it had something to do with the SD-card I use, but I experience the same behavior without any SD-card in the SD-slot.
I bought the unit just two weeks ago and it runs the 3.02 firmware.
Any ideas?
Thanks,
Daniel
Posted Aug 26, 2010 · 06:27 UTC#2
Ok - just to clear things up:
That strange behaviour resulted of the usage of a wrong testmode version.
As soon as I used the correct version once, it never happend again.
Have a nice day,
Daniel
Posted Sep 14, 2010 · 10:50 UTC#3
Well, I guess that "solution" was a little premature...
After two weeks in which the unit went without a problem, it showed that strange behavior again yesterday.
In these two weeks I haven't even performed a testmode start up.
Could it be something with the wiring? Any ideas?
Daniel
