Z110bt keeps resetting every few minutes. Help!
By felixgun · Aug 21, 2010in Problems/Troubleshooting💬 8 posts👁️ 1,525 views
Posted Aug 21, 2010 · 11:58 UTC#1
My screen has recently began resetting back to the splash screen and having to boot up. Every 2-3 minutes. It is extremely aggravating to not even be able to listen to a whole song without it resetting. I purchased in may 2010 from amazon so it should still be pretty fresh. Anyone else experiencing this or have a fix ?
Posted Aug 21, 2010 · 12:17 UTC#2
There's either a problem with the power connection, or the unit is just defective and needs to be repaired....
Posted Aug 22, 2010 · 03:06 UTC#3
check the acc wire-red sounds like you have a bad connection
Posted Sep 01, 2010 · 01:55 UTC#4
Hi there, first time post, long time vierwer of the site.
This just starting happening to me today as well. But it only happens when my blackberry is connect via bluetooth. When i disable the bluetooth on my phone and it doesn't pair up, the head unit is fine and will play no issues
Does this tell me that the Bluetooth is faulty on my device? I have rebooted my phone before repairing and I also deleted the pairing off the phone and re-added it with the same result.
any help would be appricated!
Antonio
Posted Sep 02, 2010 · 00:02 UTC#5
That sounds like it's some software issue with the AVIC, but I haven't heard anyone else (nor have I) experienced this with my Bluetooth phone. I would check the connections as others have suggested just to make sure it's not caused by that. Also it could be overheating.
Posted Sep 02, 2010 · 02:25 UTC#6
Hi Robet,
Thanks for the reply, but when the bluetooth is not paired.. No issues with the head unit..I called Pioneer and they are looking into.
OP i would suggest you do the same.
Posted Feb 24, 2011 · 03:43 UTC#7
same crap is happening to mine now. just got it back from warr. repair for screen problem. jim
Posted Mar 01, 2011 · 04:21 UTC#8
Anyone figure this out? My unit has started doing it as well. Generally within 5-10 minutes of having my phone connected via BT the head unit restarts. If not for the splash screen you hardly notice it. I've only noticed the restart when I am connected via bluetooth.
