Having experimented with the microphone by calling an answering machine in my house
I have come to the following conclusions:
1.) The microphone actually is very good at picking up low volume voice. What I've
found is that if I talk TOO LOUD - the voice gets garbeled.
2.) I'm convinced that some software engineer decided that it would be ok to couple
the microphone input level and the sound output level. The microphone seems to
work better when the system audio output (as determined by the + and - buttons in
the voice call status with the telephone hook) is set to low. Turn up the volume, the
voice at the other side (as heard on my answering machine) starts to break up.
So my recommendation is to turn the volume down and speak softly.
Its a little un-natural because I want to play the incoming voice at a higher volume
and its difficult to remember to speak softly. If I start getting louder, the caller on
the other side always starts saying "you are breaking up"
They really need to give you a microphone input level meter and let you set that independent
of the volume playback.
I think this would be relatively easy to fix - and I'm hoping it will be fixed soon.
I opened a trouble ticket with Pioneer regarding the inability to use the alphabet dial next to the
full list of artists... as someone with a 100+ artists on his ipod - its gettig to be a big problem that I can't
do "P" first then select "Pink Floyd" from the P artits. Scrolling through EVERY artists to get to someone in the
middle of the alphabet is a pain.
I think the problem is sort of caused by the Ipod. The pioneer does NOT like it if there are artists that yuo told it to use the last name instead of the first. I think if you leave every artists as sorted by first name, the Pioneer doesn't get confused. But I'm sorry, I prefer to see Eric Clapton filed under "C", not "E"...
My kid seems to think his artists should all be sorted by first name (which is how I know the Pioneer doesnt get confused = because his ipod never has my problem).
That being said the Pioneer STILL should be able to use the alphabet wheel correctly since I think thats something Pioneer did on their own - not Apple.
