Plug in XM module, HD Radio disapears?
By edrock200 · Aug 24, 2010in Problems/Troubleshooting💬 5 posts👁️ 1,033 views
Posted Aug 24, 2010 · 02:29 UTC#1
All,
Intalled my z120 yesterday with MSN, HD radio tuner and xm920 module. All was working fine, XM and HD Radio. Today randomly the XM went out. I pulled the XM module out and disconnected it. HD radio comes back. I swapped the 920 module with my old 10xmt module, same issue, HD Radio disappears. Unplug it HD radio comes back. Here's the odd part, if I just plug in the IPBUS cable to the xm module, HD radio stays on screen, as soon as I attach power to the xm module (either 920 or 10xmt) the HD Radio and XMRadio icons disappear.
In none of the scenarios does XM show up anymore. Do I have a defective head unit? I read another thread about an IPBus issue when more than 2 modules are connected, the z120bt has a bug where it drops connections. Not sure if thats true or not.
Anyway, before I tear the unit out to troubleshoot I was curious if this is a known issue or if anyone has run into this? I just don't want to reinvent the wheel while troubleshooting this. Any help would be appreciated.
Posted Aug 24, 2010 · 03:11 UTC#2
make sure you have your IP-bus wires INS and OUTS correctly. I have a Z110BT and have HD and XM with no problems.
Posted Aug 24, 2010 · 04:15 UTC#3
Cables are in correct order. Unit was working fine, then just stopped.
Posted Aug 24, 2010 · 19:07 UTC#4
Checked the connections again. All is ok but still no xm. Also updated to latest firmware. Anyone?
Posted Aug 24, 2010 · 20:33 UTC#5
Try swapping the tuners around on the bus.
