I have been looking through the board and have found some great info on the use and installation of my new D2, but was hoping for some help. I have found from here and the f-150 board that the easiest VSS hookup is going to be on the factory radio harness - gray and black wire, my stock stereo had the speed controlled volume. But what I wanted to try and find out is where is the easiest place to tie into the reverse sensor? I am currently running wihtout either hooked up and want to install the VSS now that I know where to tie in at, but only want to take the deck out once and hopefully hook up both. Thanks for any help - Erik
Posted Dec 23, 2006 · 18:07 UTC#1
