adding a Aux (pioneer z1)
By yamahatundrav8 · Aug 28, 2010in Problems/Troubleshooting💬 11 posts👁️ 4,141 views
Posted Aug 28, 2010 · 16:44 UTC#1
A wile back my friend added a radio shack cable that went into my Input from the rear of my Pioneer z1 (see pict). I recently purchased a Apple Iphone4 and trying to use pandora from the headphone jack and it doesn't appear to have any sound at all. I tried to add a couple of other sources and still no sound? Any ideal what im doing wrong. i checked the settings on the unit and have an open line on Aux. Do i need to purchase another cable to get this working?
Posted Aug 28, 2010 · 18:02 UTC#2
What cable are you using from the phone to the AV input cable on the unit?
Posted Aug 28, 2010 · 18:13 UTC#3
something like this is hooked behind my z1 currently. It's worked before and now I don't seem to have any sound coming from the unit into this Input.
Posted Aug 28, 2010 · 18:22 UTC#4
Are there two or three black rings on the plug that goes into the phone?
Posted Aug 28, 2010 · 18:26 UTC#5
From the pic he posted it looks like two.
Posted Aug 28, 2010 · 18:28 UTC#6
Correct 2 bands. Iphone4 has 3 white bands from the looks of it on the Oem apple designed headphones.
Posted Aug 28, 2010 · 18:38 UTC#7
Yeah, you need one with three bands. I'm surprised this thing actually worked for you in the past, that isn't normal.
Posted Aug 28, 2010 · 22:18 UTC#8
It worked from this method a wile back but it wasn't an iphone in fact the iphone first gen didn't work either. If i recall it was a mp3 type music player that worked and played but that's been a wile (2007).
This is what I like to do right now either figure out how to add a cable that would charge the iphone4 yet retain pandora (aux) and play music. It would play directly to the z1 (wired) aux any lead's????
Posted Aug 28, 2010 · 22:26 UTC#9
Well thats easy, Apple Composite AV Cable. It will plug directly into the AV1 inputs of the Z. Also get a USB to Cigaret Lighter Adapter so you can charge the phone. Otherwise you need to get the proper AV 1/8" to RCA cable that has three rings on the plug if you want to continue to use the headphone output on the phone. Either of these solutions will solve your problem.
Posted Aug 29, 2010 · 01:44 UTC#10
Also, it's not the "AUX" input. You need to use the source "AV Input". In the settings, set "AV Input" to "Video". The wire you have should work fine for audio. Standard "stereo" headphones with 2 bands will work on any iphone...
Posted Aug 29, 2010 · 02:21 UTC#11
Thanks Garrett it works now :D I sort of had a feeling it was a setting issue just wasn't sure. I added the pax steering wheel control a few mo's ago and the settings went back to factory Pioneer so it might have changed that.
Erik
