My HP6515 from Cingular paired up fine with the Bluetooth module and works better than the Nokia Bluetooth car kit I was using before. No echo for me. However, the phone will not "Register" with the Z1. HP6515 does not show up in the list when I try and register from the Z1. Not a big deal I guess since the Bluetooth is working fine.
Also, as I stated before I had the unit installed by a national retail chain and in my opinion they did a poor job. F350 crewcab required some dash modification to accept the Z1. The installer did not use the trim ring around the unit and there is a small gap on each side. Also, they did not return some unused parts from the Z1 package even though I expressly told them that I wanted all the parts and packaging left in my vehicle. On the connection status menu it shows "excessive vibration". This vehicle is a diesel truck and I don't know if the excessive vibration can be cured.
How would you all handle issue two? I could probably go into complain mode long enough to get them to refund the install cost.
Any thoughts on issue one?
Thanks in advance.
