in my 1999 toyota land cruiser, i'm using the metra 70-8112 harness.
i did the mute pin bypass and hooked the newly positioned mute pin
and the parking brake to ground.
i hooked the yellow constant 12 v from the metra harness to yellow
wire on the x920-bt power cord, and from the red accessory switch
wire from the metra to the red wire on the power cord.
i also tied the amp and antenna wires from the metra to the blu/white
i tested the unit first to make sure that the unit works - and it does.
the problem i'm having is that the unit powers up with the key in the
off position, and the radio works. when i turn the key to the acc
position, the auto antenna flips up, and it flips back down when i
turn the key off. however the radio is still running.
this looks like i mis-wired the red acc and yellow constant wires.
before i do flip them and lose a little bit more wire, i just wanted
sure that i'm troubleshooting this correctly. could anything else
be wrong?
