Changing source to Pandora via voice control on Z-120?
By syardell · Aug 31, 2010in General💬 2 posts👁️ 991 views
Posted Aug 31, 2010 · 00:02 UTC#1
How does one change the source to Pandora using a voice command? There's nothing on this in the manual.
By the way is it an annoyance of anyone else that the location on the touchscreen for the different sources is always moving around depending on what source you are currently in? Makes me have to look at the screen more than I want just to switch from Pandora to FM.
Thanks.
Posted Sep 17, 2010 · 01:07 UTC#2
you can't change it to that source because in order to use Pandora, you need to activate the PandoraLink software manually on the iphone. I suppose if you have the app enabled all the time, that wouldn't be a problem, but I expect you also want to play your music files from the iphone as well.
