reset screen goes black
By imcadillacrob · Aug 31, 2010in Problems/Troubleshooting💬 2 posts👁️ 858 views
Posted Aug 31, 2010 · 16:33 UTC#1
ok after doing research, on how to update the f900bt, i bought the sd card downloaded software from pioneer website, i held reset along with 3 buttons insert key code and then once if gives me the 5 options, the unit restarts, what gives? im getting irritated with this unit some one please help.
Posted Sep 04, 2010 · 01:46 UTC#2
If you don't get the first part, pushing the 4 buttons, just right it will restart after 10 seconds. Here's some comments from this post viewtopic.php?f=34&t=25751
I never heard a pop sound from my speakers when I did it.
Step 4: Turn unit on. When the pioneer logo comes up, press and hold the menu, map, eject and the reset button at the same time. When you hear a pop sound from your speakers, let go of the eject button but continue to hold menu and map buttons. This will bring you to a blue screen where you will have to enter the service combination. Press the volume knob in this sequence and you will see * signs for each push: Up, Up, Down, Menu, Left, Right.
Re: Complete 3.0 Install Guide
Postby pwnin o'brien on Sat Jul 18, 2009 3:05 pm
HELP!!!
When I get into the service menu, my screen will go black after 20 or so seconds. Even once I get to Update via SD (Format) and I click it, it will start reading the files and then the unit will just go black. This happens every time, even if I go into the service menu but don't click anything. When I reboot the unit (without trying to get into the service menu), the screen just stays black, nothing comes up. I have 2.006 installed on my F900.
Once I reboot the unit I can successfully get back into the service menu, but then it goes to black screen.
Postby pwnin o'brien on Sat Jul 18, 2009 3:21 pm
Nevermind, figured out the problem.
You have to hold all four buttons, then release the reset button first, then release the eject button, then you get the blue screen (without a time limitation). I also got no pop from the speakers, I just guessed on timing.
