Settings page mostly greyed out . . .
By Hodo · Sep 01, 2010in Problems/Troubleshooting💬 24 posts👁️ 72,737 views
Posted Sep 01, 2010 · 10:38 UTC#1
Ok, had my Z120BT installed this past weekend and went into the settings page and of the 6-8 options available on the settings page 3/4 of them are greyed out (nothing happens when I touch them), only AV Audio and one other option are in full color (and work when I touch them). Why is this?
Also, what menu is the time set in? And how do I turn off the "beep" (or at least adjust the volume lower) every time I hit any button or any on-screen icon?
TIA,
David
Posted Sep 01, 2010 · 12:21 UTC#2
Set your parking brake and your buttons will not be gery anymore. This is by design, unless you do the bypass as described int he sticky posts (hacks forum).
You can set the time, only the time zone (regional settings). There is a setting option for the beep volume. Have you looked at your owner's manual yet??
Posted Sep 01, 2010 · 12:46 UTC#3
I've started to read the manual, but it's pretty big . . . no excuse, I know.
Thanks for the tips, will try why stationary. Guess my installer messed up the bypass (I provided the info from this site, don't know why he didn't do it).
Thanks again,
david
Posted Sep 01, 2010 · 14:46 UTC#4
You may want to download the PDF manual from Pioneer. It's great to do quick word searches like "time" and "volume". Much quicker than trying to find it in the paper manual.
Posted Sep 01, 2010 · 18:18 UTC#5
most places wont do the bypass for liability reasons
Posted Sep 01, 2010 · 18:24 UTC#6
Yeah, I know, but this guy did my install "on the side" and agreed to do the bypass for me before hand. I even provided him the pic and description from the bypass thread on this forum . . . somehow he goofed it up, which isn't giving me a lot of confidence about the rest of his install -- don't get me wrong, I was there for 90% of it, and his interior tear down and speaker wiring (had him install six new speakers, two of which were in new/fabricated locations) and amp install skills were good based upon my un-trained eye, but I think this may have been the first time he installed a head unit/nav of this complexity.
Posted Sep 01, 2010 · 18:57 UTC#7
Just take it back and have him follow the directions on this forum. If he tries to use some other method, tell him you want him to do it the way it states on this forum.
Posted Sep 01, 2010 · 20:29 UTC#8
i really cant understand how so many people have problems following the instructions here, there is really only three steps, ground the p-brake wire, move the mute wire and then ground the mute wire, if somebody cant follow those steps with out messing it up (and believe me there are sooo many people who cant), then they really dont have any business behind the dash board.
i would say that the most common issue people have is the they move the mute wire to the wrong pin or that they dont push the mute wire in all the way, but this is very easy to identify, as there will be a "incorrect connection of p-brake" message, and that the unit will work while stopped but after you get up to a certain speed it cuts off, if you are not getting one (or both) of these issue, then you problem is different.
Posted Sep 01, 2010 · 20:30 UTC#9
also make sure you got the right bypass instructions for the unit you have as there are slight differences with some of the different models
Posted Nov 06, 2010 · 17:59 UTC#10
I've tried starting up the engine and having my foot on brake and ebrake pulled as far back as possible, yet all the options are still greyed out. Possibility my mechanic could of done a wrong bypass... he just told me he made it so the car doesn't have to be parked to make use of the navi
Only none greyed out variables on the console are my AV source and like a few random things in the navigation area... can't pair my phone or anything... I know the bluetooth works and the gps works simply because my phone see's the console, and I can see where I'm going on the map... just can't manually input addresses or anything -.-
Posted Nov 06, 2010 · 18:36 UTC#11
it appears my mechanic thought that by not hooking up the ebrake cable or brake cable or w/e that he was bypassing the no navi while drivey crap
therefore I can't do anything about the settings until monday since he's busy. this sucks... is there any pictures or anything that show how to connect the brake cable? I could do it myself, just don't see anything mentioning that step in the installation manual
Posted Nov 06, 2010 · 22:22 UTC#12
I hope you didn't pay much for that installer. Didn't he even test the system?
I only have the Z110 Installation manual. On pg 12,
Light green
Used to detect the ON/OFF status of the parking brake. This lead must be
connected to the power supply side of the parking brake switch.
If this connection is made incorrectly or omitted, certain functions
of your navigation system will be unusable.
WARNING
LIGHT GREEN LEAD AT POWER CONNECTOR IS
DESIGNED TO DETECT PARKED STATUS AND MUST
BE CONNECTED TO THE POWER SUPPLY SIDE OF THE
PARKING BRAKE SWITCH. IMPROPER CONNECTION
OR USE OF THIS LEAD MAY VIOLATE APPLICABLE
LAW AND MAY RESULT IN SERIOUS INJURY OR
DAMAGE.
It even shows a picture of a parking brake and a sample diagram. I'm sure the Z120 manual is nearly identical. Are you sure you aren't looking in the User's Guide? You can download the Installation Manual from Pioneer.
If you are going through all that, you might as well do the bypass youself. It is well documented here and even You Tube has videos.
Edited Nov 06, 2010 by RonS
Posted Nov 06, 2010 · 22:41 UTC#13
Search the install manual to see how to attach the P. brake as designed. Search this forum to see how to do the bypass.
Posted Nov 08, 2010 · 15:52 UTC#14
ROFL, do you mean like what was recommended in the very first post of this thread
Posted Nov 08, 2010 · 18:53 UTC#15
Yep, just like that. :)
Posted Nov 22, 2010 · 11:15 UTC#16
right, like that's not obvious... I already had gone through and searched for what I was in need of assistance with, and that brought me to this thread... in any case I resolved the issue myself and modded/bypassed the safety crap which restricted me from doing anything while driving, dumb idea in my opinion... if you have a passenger why are they somehow incapable of messing with a navigation system or watching a video simply because the driver cannot? rhetorical question.
Posted Nov 22, 2010 · 13:49 UTC#17
This is the case with every aftermarket in dash navi that is sold in the US. If you think about it for just a little second, it actually makes sense why they do this.
Posted Nov 22, 2010 · 14:24 UTC#18
And most, if not all, factory units. Same liability issue.
Posted Nov 23, 2010 · 02:12 UTC#19
I think it should be an option... disable front view restriction? yes/no
if anyone gets into an accident from being distracted, that's their own fault, they shouldn't be allowed to drive haha
Posted Nov 23, 2010 · 04:49 UTC#20
I agree with you, BUT, the issue in our country is everyone wants to sue everyone else at the drop of a hat. Pioneer is covering their ass.
Posted Nov 24, 2010 · 14:29 UTC#21
i would have to respectfully disagree with you, stupid people would just disable it right away and drive around with movies playing, my life shouldn't be put at risk just because some kid thinks hes cool and is showing off for his friends and gets distracted. and it wouldn't just be the drivers fault, pioneer would have a huge stake in the liability of it since they programmed such an easily defeatable lock out.
Posted Oct 01, 2017 · 17:51 UTC#22
Hi, sorry to revive such an old thread but its the only thread I can find which relates to my problem. I just fitted a Pioneer NEX8000 (actually UK version called F60DAB, but its almost identical). Someone above said the greyed out menu items are due to parking brake bypass not being done. Mine is definitely done, but I still have an option greyed out. The "power to antenna" option. Its set to NO, but I can't change it. if i touch it nothing happens.
Having just installed the stereo in my Audi A6 (which has a built in DAB antenna), I can't get DAB reception on the head unit whether I use the Audi built in plug, or the glass mount antenna which came with the stereo.
Any ideas anyone? thanks
Posted Feb 28, 2023 · 03:35 UTC#23
I’m having issues with my pioneer avic_x71OBT greyed out issues
Posted Mar 16, 2023 · 01:05 UTC#24
Check brake or brake wire
