X920bt update failed
By SolidForce · Sep 01, 2010in Problems/Troubleshooting💬 14 posts👁️ 5,889 views
Posted Sep 01, 2010 · 19:11 UTC#1
Recieved the sd card from pioneer yesterday. Popped it in today and it fails at around 40/105. Any ideas? Bad software?
Posted Sep 01, 2010 · 19:15 UTC#2
Why did you receive an update card from Pioneer? The update can be downloaded from their web site.
Posted Sep 01, 2010 · 20:28 UTC#3
Did not have a microSD card and it was free so I said...what the hell :mrgreen:
Too bad it does not work. I guess I can try and find an adapter or something to try and reupload the firmware to the card.
Just seeing if anyone else has run into the issue.
-SF
Posted Sep 01, 2010 · 20:40 UTC#4
Yea thats what I would do. And you can get SD cards and adapters at Walmart all day long for cheap.
Posted Sep 11, 2010 · 23:38 UTC#5
Did you ever solve the problem? I came across the exact same problem -- my unit won't read the SD card at all.
Posted Sep 12, 2010 · 18:25 UTC#6
do you mean a factory card, or one you made yourself?
Posted Sep 12, 2010 · 19:48 UTC#7
Both. I tried the factory card--nada. I then formatted the factory card, downloaded the update, loaded it onto the factory card--still nothing. I then went to Best Buy, bought *another* micro sD card, formatted it, loaded the update onto it, and tried it. Nothing. My unit doesn't recognize that there has been an sD card inserted.
Posted Sep 12, 2010 · 20:24 UTC#8
gnarly. I went to two auto stores, and both would read jpg data, and mp3 data, but neither would read any of the seven different video formats I had on the cards
Posted Sep 14, 2010 · 20:56 UTC#9
Did you a:) turn off ignition, b:) insert disc, c:) turn on ignition? If that was the order of operations you followed, it should have worked. Any success?
Posted Sep 15, 2010 · 01:58 UTC#10
Did that (with two different SD cards) -- unit simply won't recognize that an SD card has been inserted. The unit is only about a month and a half old, and this is the first time I've tried to use an SD card in it. The wonderfully helpful (sarcasm) folks at Pioneer Support told me that I would have to send the unit in for repairs at my expense. When I told them that I bought the unit from a dealer, and had no idea how to properly remove it from my car, they essentially stated that that wasn't their problem, and that I would need to pay someone to remove it from my car, if the dealer wouldn't.
So, even though Pioneer sold me a defective product, I need to pay through the nose to correct their error. Unfortunately, I'm stuck with this bug-ridden piece of crap until I sell my car, but I'm never buying a Pioneer product again.
Posted Sep 15, 2010 · 02:56 UTC#11
I know you're upset that you have what you consider a piece of garbage, but they have a point, what do you expect them to do? if you bought from a dealer, then the dealer should be part of the resolution, and that would include removing the unit.
In all seriousness, what did you expect them to do here? they're saying send us the defective unit, they will fix it, that's generally the way it works.
Posted Sep 15, 2010 · 05:02 UTC#12
on the other hand, if you told them YOU installed it yourself, they would likely wash their hands of the whole affair. Last time I checked, there was no "degree" available from USC for auto-sound installation. In other words, I would hope Pioneer would stand by their product no matter who installed it.
Geez - I guess you have to read a 200 page manual and try every single feature in the book within your return period. What has become of the great technology companies? Even Toyota's are killing people.
Posted Sep 16, 2010 · 02:57 UTC#13
ok, just finished the re- install of a new x920 bt. as soon as it was up and running I checked the mini SD drive, and it seemed to accept data, as in music. took the factory pioneer update disc - 200.3000 or whatever it was. turned off the ignition, inserted the factory disc, turned on ignition in ACC mode, and the update booted no problem. it took about three minutes to complete. it rebooted no problem and now it seems fine. Although, I can't be certain, but the Bluetooth that people hear from the car may even be a little worse than before the upgrade. Which of course, would be impossible, wouldn't it?
Posted Dec 20, 2016 · 23:56 UTC#14
I just purchased a vehicle with this unit installed, tried to update several times and mine fails at about 16/105. How did you finally get it to work.
