Problem with avic-f9110bt
By myrka00 · Sep 02, 2010in Problems/Troubleshooting💬 6 posts👁️ 1,668 views
Posted Sep 02, 2010 · 06:36 UTC#1
The problem is that the unit is very very slow, when i change a song on sd card or usb stick yhen the unit usually crash-is and about few minutes is back normal. Allso when I am on navigation map then the song dosen't change (when the song is over or i change it). It allways helps when i press the menu button, but it isn't normal to press allways the menu button when i want to change a song or a video.
Can somebody help me?
Sorry for my bad English.
Posted Sep 27, 2010 · 10:24 UTC#2
dosn't really anyone know a solution for this problem?
Posted Oct 29, 2010 · 09:30 UTC#3
do you have map hack?
Posted Oct 29, 2010 · 15:01 UTC#4
make sure that your software is up to date, you may have a corrupted file or two.
Posted Dec 13, 2010 · 19:09 UTC#5
Hi 1loudls,
Is there a way to check if there are any corrupted files? I am experiencing the same problems with my F9110bt unit.
Regards,
Joop
Posted Dec 14, 2010 · 13:59 UTC#6
not that i know of, try reloading the latest up date.
