help:x910bt movie lag
By blade80 · Sep 03, 2010in Hacks/Mods💬 3 posts👁️ 1,349 views
Posted Sep 03, 2010 · 02:08 UTC#1
hi all. i just got x9115bt = x910bt and just finished install with bypass.
looks like everything works fine but the movie from USB lags. i did all the search but i couldn't fine my answer here.
do anyone know how to solve or is there some format that i have to convert?
Posted Oct 20, 2010 · 22:38 UTC#2
In your owner's manual check apendix page 198-199. Make sure to maintain bit rate which is responsible for lag time.
Posted Nov 26, 2010 · 17:03 UTC#3
The bit rate as previosly mentioned is important. One other thing is that not all USB drives are created equal. They come in different speeds just as any other memory does...including SD cards. I had the same problem with my Verbatim USB drive so I moved the files over to an OCZ USB drive and it works flawlessly.
