2010 is almost over and still no 2010 maps. Whats up with that. I guess buying a f500 was a bad idea. I should have kept my hand held Garmin.
Where are the 2010 US Canada maps
It is not a bad idea if you know where to look. They are not available here, but there are other sites where you can download them. You can also purchase the new maps from Pioneers website. Do a search!
Are you telling me that you have the 2010 canada maps. It does not show up on the pioneer site.
No, the latest Pioneer maps that I have are dated 2009.12, which came out 2010 in the first quarter. I think that they are the same that are being offered on the Puioneer website for $120, but I am not sure. There is a thread on it here somewhere.
Must be the same as I have. THNX
I downloaded it today. But haven't had time to load it yet.
Give it a try. ![]()
i loaded the latest TA 2010.06 maps yesterday from a site similar to gpsunderground. the maps work great, i also have the latest navteq maps just to check them out later, however i had to delete a few maps and POIs in order for it to fit.
Where did you find the maps? All the maps from GPS Underground are dead!
me too please.
Hmmm, I got the 2010.6 maps, but not to much has changed. New streets that they put up here mid 2009, still are not on these maps
. Not much change over the 2009.12 maps
Can you share them please.
Too big to share, you have to get them yourself. I got them from Navitotal, but others have gotten them from GPS Underground.
i got them from navitotal, it really doesnt take to long to download all the files seperately, took me about an hour. i really havent noticed a change, but its just good to have newer maps, i just moved to a new area so i dont know what roads are there and arent. but my parents house which was built in 2003 now shows up in the maps, where are my previous maps said the address was not available. there are more accurate speed limits though.
Anyone else have an issue with the unit booting up to the USB directly?
I was able to get the TA 2010.6 maps from GPSunderground but the Generic License Code and EZrider files were not included. Are they required if I already have the TA 2009.6 maps installed? Thanks!
I am using the same easy rider file and license and it works fine.
What about the new POI files that come with the new maps? For instance I swapped out TN map with new version, but the new PIO for TN was 5MB than old poi file and it told me there was not enough space?
Delete your old files first before installing the new ones. If you are still out of space, delete some maps that you dont use or delete some POI's that you dont use. For example, why would you need POI's for Alaska if you live in Florida?
Well I ended up removing California Map an POI as well as Canada, PR and Hawaii, now I fit all other new maps. I only updated the POI files for areas near where I live.
I'm running a 700bt running FX3.1, if I wanted to update my maps would I need the maps for iGo 8.0 or 8.3? Thanks!
8.3
I'm running a 700bt running FX3.1, if I wanted to update my maps would I need the maps for iGo 8.0 or 8.3? Thanks!8.3
Thanks! I just downloaded 2010 Q2 maps and premium POI and I have to cut out quite a bit of POI's and states to make them fit.. I wish we had a 4GB flash nand instead of 2GB.
