new owner with problems z120bt
By biggz1 · Sep 04, 2010in Problems/Troubleshooting💬 20 posts👁️ 2,975 views
Posted Sep 04, 2010 · 03:48 UTC#1
hi to all i have a couple of newbie questions yes i searched the forum couldnt fine any answers ..new 120bt install i can stream audio with iphone4 but when i hookup cable for ipod songs are playing but nothing coming through speakers any ideas what could be causing i tried looking at settings cant find nothing second when getting a phone call i could hear whos calling but they cant hear me what could be causing this im going crazy..thanks
Posted Sep 04, 2010 · 08:47 UTC#2
Your iPhone is using the BT audio out when you have it hooked to the cable. Hit the BT symbol on the bottom right of the transport control on the phone and set it to DOCK CONNECTOR.
Your second issue sounds like you are answering from the phone itself. If you do that the audio out of the phone will go to speaker and not BT out. Answer from the screen of the unit and all should be good.
Lastly, in the future be sure to post in the proper forum. You posted this in the X series forum.
Posted Sep 04, 2010 · 13:04 UTC#3
Hey blue is that you .. Well sorry for the mixup still havent got it i have iphone 4 theres no button on right side even if i turn off bt and hook up cable i can see its playing but no sound
Posted Sep 04, 2010 · 17:27 UTC#4
Do you have the Pioneer iPod cable?
Posted Sep 04, 2010 · 19:41 UTC#5
Yes original cable.. Its reading on screen i could see the track playing but no sound
Posted Sep 04, 2010 · 22:12 UTC#6
Make sure the AV cable is plugged in.
Posted Sep 26, 2010 · 23:00 UTC#7
I have the same problem with my ipod touch and nano. I'm using a regular ipod cable rather than the pioneer, but other people seem to be able to use this without issue. I have AV1 set to ipod. I have all the cables hooked up. The system is controlling the ipod and the song is playing but there is no sound. Do I have a defective unit?
Thanks.
Posted Sep 26, 2010 · 23:03 UTC#8
No one is using the Apple iPod cable with these units. If you read your manual it clearly states you must have the Pioneer iPod cable.
Posted Sep 26, 2010 · 23:09 UTC#9
Thanks.
You haven't seen that on this forum. Because it won't work on a Z1x0. You must have the Pioneer cable (or a very good knock-off - don't bother looking - not worth it). Otherwise, all you'll get is the display of track info - with no sound.
Posted Sep 26, 2010 · 23:17 UTC#10
Guess I read/remembered some other posts wrong. I found this one which supports your advice:
viewtopic.php?f=48&t=34691
Of course I read the manual. But manuals rarely if ever contain all relevant information. Thanks though.
Posted Sep 26, 2010 · 23:26 UTC#11
If iPod video support is not important to you and you want to go really cheap, you can use the Apple sync cable and an 1/8" cable from the headphone out on the phone and it will give you audio. Too me however, it seems much easier and less hassle to just purchase the Pioneer cable, get full support and only have to be concerned with plugging in one cable.
Posted Sep 27, 2010 · 02:37 UTC#12
Hmm. No. I tried that already. Didn't work. Does this work on yours?
Posted Sep 27, 2010 · 02:42 UTC#13
It will work on any.
Posted Sep 27, 2010 · 09:00 UTC#14
Is your vehicle equipped with a premium audio? BOSE, infiniti, Rockford Fosgate, NDDS, Harmon Kardon, etc?
If so, verify the remote turn on wire off the AVIC is hooked up to the AMP turn on wire (blue/white or blue if no blue white exists) of the vehicle's harness.
Check a CD or DVD to see if you have no audio on those sources. If the same problem exists, you have a wiring issue. It can mean the power antenna wire of the AVIC (blue wire) is hooked up to the vehicles amp turn on wire. If thats the case, audio will only work on AM/FM source and be audio-less on all other sources. Blue wire on AVIC only ouputs voltage to operate an ampified or power antenna. The blue wire shuts off on all other sources cause theres no need to have the power antenna on.
Posted Sep 27, 2010 · 17:40 UTC#15
It is possible that this might be the problem. My car (1993 Mazda RX7) *didn't* have the premium audio (bose) option, although this was an option on some models. I had the antenna wire from the avic connected to either the blue or blue/white wire on the car harness (don't remember for sure, and I'm not near the car right now). It annoyed me that the power antenna went up when every source (not just am/fm) was selected. However, CDs and DVDs *do* play just fine. So I'm not sure how much this issue is related to the no-sound-with-ipod issue.
Currently I have all blue wires disconnected. I don't think I checked ipod sound (with or without 1/8" audio cable) in this configuration. I will check tonight.
Thanks.
Posted Sep 27, 2010 · 19:34 UTC#16
If you don't have audio plugged into the 1/8" input from the Pioneer iPod cable you wont get audio.
Posted Sep 27, 2010 · 20:32 UTC#17
Indeed. Problem is, so far I have not had ipod audio even with the 1/8". But I will try again tonight with the disconnected antenna wire. Thanks.
Posted Sep 27, 2010 · 23:25 UTC#18
Something else is wrong. Make sure the AV1 input is set to iPod and that the iPhone headphone output is not defective. You can even set AV1 to VIDEO and just plug the iPhone headphone output into the 1/8" AUDIO in and hit play on the iPhone just to test that it receives audio. If it doesn't you have an issue with one of the two audio connections or a bad cable.
Posted Sep 28, 2010 · 14:29 UTC#19
Turns out that gtsdohcvvtli was correct. There was an issue with the "blue wires". After disconnecting all blue wires (i.e. my antenna stays down and there is no factory amp) I now DO have sound from my iPod (with the 1/8" cable). Yay.
Thanks very much gtsdohcvvtli.
I have already ordered the correct cable since I do want video support, but it's good to know there's nothing wrong with my avic.
By the way, it's pretty frustrating that there are two very similar pioneer ipod cables: the CD-IU50V and the CD-IU50. Note the part numbers are identical except for the "V". Originally, I mistakenly ordered the one without the "V". Just mentioning this in the hope it prevents someone else from making the same mistake.
Posted Sep 29, 2010 · 22:20 UTC#20
Try unplugging your ipod from the cable and plug it back in..the sound should work.
