Best way to mount the 3.5mm on the dash ?
By TXFrdOwner · Sep 05, 2010in Hacks/Mods💬 5 posts👁️ 1,638 views
Posted Sep 05, 2010 · 18:50 UTC#1
Has anyone found a clean (factory look) way to mount the 3.5mm (iPod Connector) on their dash ?
I went with the iS335 or PDM35 at first but it only does audio and not video.
Any suggestions ?
Posted Sep 05, 2010 · 20:35 UTC#2
What do you mean you want to mount it on your dash?
Posted Sep 06, 2010 · 17:48 UTC#3
I wanna make it look like this picture below. Actually thats what i'm using right now, but because this pac cable only does audio and not video I can't get my ipod/iPhone movies to show on my Z110BT.
So here's a picture from the manufacturer:
And these are from my installation in my 2007 Ford Expedition:
Posted Sep 06, 2010 · 18:33 UTC#4
Well you could always check Radio Shack for an extension cable that might work.
Posted Sep 07, 2010 · 19:35 UTC#5
drill a hole, that is exactly the same size as the pioneer plug, then stick the pioneer plug into the hole and secure it with a fair amount of epoxy form the back side. you may want to use a little bit of hot glue to hole the connector in place while the epoxy sets up.
