ya just trying to see what others put on their sd cards for the x920bt so far i only have poi from avic feeds and some music files and some splash screens let me know thanks
what do u guys put on your sd card?
I use the SD card to store my music videos, movies, splash screen images.
i tried mpeg4 it didnt work wut format did u use and where did u get the vids from thanks
yeah, I second that request - what format, how did you convert, framerate, extensions etc thanks
There's a thread on this General section that explains format u can play on SD.
Anyone know of a method converting M4V itunes format with DRM to AVI ?
thanks - I read that thread - sorry, should have mentioned that. Used a Divx converter - nothing would play. I don't think that thread mentioned if extensions should be .divx or .avi, and which converter was preferred
music, porn, and the "my flash drive" backup, and thats all, mostly porn though
using ffmpegX on Mac OSX for encoding.
Possible CAPS:
1GB maximum file size
1000 kb/s maximum video bit rate
VIDEO
CODEC: XVID ffmpeg (*.AVI)
RESOLUTION: 640 X 360 for full screen or 640 X 272 for top/bottom bars
FRAME RATE: 23.97 or 29
BITRATE: 900 kb/s
AUDIO
CODEC: MPGA
BITRATE: 128 kb/s
SAMPLE RATE: 48kHz
Woah you watch p0rn on yours? ![]()
you guys dont, how else am i supposed to fill a 4Gb SD card and a 80Gb ipod?
I'm testing out a Windows video converter, AVS Video Converter. Seems to work good, tested out a few vids already.
what is the extension that the Pioneer understands? Does it understand more than one - .avi. divx. mp4 etc?
also, what resolution are you finding works best
I've only been able to play XVID MPEG4 (*.AVI) so that is what I use. 640X360 works good.
Been there also ; was kinda time wastin’ to try to convert protected m4v to avi from Itunes with a lot of converter apps or what you call’em until actually managed to find a good solution outta this.
Anyways, solved my problem with some Tunebite Converter app.
Used Tunebite to convert protected m4v to avi, t'was actually pretty easy.
Dunno, give it a try, should work for u.
Thanks - I'll give it a look. I don't really care about "protected" files, but just finding an extension and resolution that the overly fussy Pioneer likes would be good.
To answer the original post. I put some music on mine, but disappointed that album art is not support through the SDHC card. Oh well.
Well, since Tunebite actually works, besides converting protected videos, to convert a ton of other file formats, u shouldn't have any problems with it.
