I recently installed a z120bt in my 2008 Silverado. This is actually the second install, the first one I did was with the PAC OS-3BOSE adapter, then realized how much cleaner and easier it was to use the OS-4 I tore it all out and redid it. The issue I am having was the previous install as well as with the one I just finished with.
I will be listening to music, either XM, FM, iPhone, it doesn't seem to matter, and the sound will just drop. The last time it did this I was just going into settings when it happened. Strangely enough, if I put it on XM and wait a bit the volume will slowly creep back up, on XM. It still has no output on the iPhone or FM/AM. Also, when it does this on the XM channel, if I turn the volume up on the stereo it has no affect, then eventually slowly starts to go up after a long delay, and the same when I turn it back down. This happens with or without my iPhone plugged into the unit.
The only way I have been able to get it to return to normal is shut my truck off completely causing the unit to reboot. After that everything is normal again until it happens again. I haven't been able to pinpoint exactly when or why, it seems random, but frequent. I have the pioneer XM tuner, pioneer backup camera (which isn't plugged in yet, but is wired), overhead drop down video monitor, iPhone 4, PAC OS-4 and PAC SWI-PS adapters. I have the bypass mod done.
Could this have something to do with my bluetooth connection to my phone? Any insight would be great. I searched a bunch and even went through many pages of posts individually looking for something similar but never found anything.
Thanks.
