Any trick to check the speed signal ???
By yannthekeys · Sep 11, 2010in General💬 7 posts👁️ 1,379 views
Posted Sep 11, 2010 · 06:07 UTC#1
Hi everyone i just installed my f700bt with the manufacturer's harness ( CARPI221 ) everything works fine, but i wonder if the speed signal is detected . Is there any trick to check it ?
Posted Sep 13, 2010 · 14:23 UTC#2
not really, other than using a digital multi meter to verify that you have the right wire, their is no connection menu like the older D-series to confirm that every thing is functioning properly
Posted Sep 13, 2010 · 17:39 UTC#3
Thanks for the answer.
Posted Sep 13, 2010 · 17:42 UTC#4
Get underneath a parking structure and see if the GPS still tracks you on the map.
Posted Sep 13, 2010 · 20:34 UTC#5
or just place a small sheet of metal over the antenna
Posted Sep 15, 2010 · 05:17 UTC#6
Good idea, i will try. But it's a pity that on chinese low cost Navi system, this option is available as lot of others ( beep disabling...). What is pioneer searching for ??? No more customers ???
Posted Sep 15, 2010 · 14:03 UTC#7
pioneers design staff has been, well...
...off there game for the past few years is seems, hopefully they can get this boat turned around
